Display flashing problem
nwuser1
Has thanked: 3 times
Postby nwuser1 » Wed Nov 18, 2015 10:07 pm
Hello to all!
Have problem with utcomp-pro oled-display, it flashes with frequency about 1 Hz all working time :( , but before shutting down, there is a summary picture about 5 sek. and this is still picture(not flashing).
Does somebody already solve this problem? What can cause like behavior?
Thanks for answers!
Re: Display flashing problem
Postby ArT » Thu Nov 19, 2015 7:26 pm
Software is checking communication with OLED every 1 second. If CRC is not correct, than UTCOMP module reinitialize OLED display (it will disable dispaly and enable so you will see blink).
1. Are you using standard 100cm tape from set? (the same situation may be on longer tape) Is it not damaged?
2. Are you using original display from set?
3. When did it happen?
nwuser1
Postby nwuser1 » Fri Nov 20, 2015 6:28 pm
Exactly, the longer tape. I changed tape to ~2,4 m tape, because i needed to place it to overhead console.
Is there problem, that resistance from utcomp to display is too big, or some another problem?
Can I somehow overcome it?
Thanks for info!
Postby ArT » Fri Nov 20, 2015 7:35 pm
We will check it on next week and try to find software solution for a such long tape. Please write me your mail on PM so I can sent you custom update later.
Postby ArT » Mon Nov 23, 2015 2:24 pm
I have sent you an email with custom update. Please check it and let me know if it help.
nwuser1
Postby nwuser1 » Mon Nov 23, 2015 9:26 pm
Thanks a lot, it really helped! No flashing any more. :D
Now all OK. Thanks.
axel
Postby axel » Thu May 14, 2020 6:48 am
can i have that update to?
I have changed the cable for a longer round one, to help me place the datalogger in a safer place.
But I also get the flashing
Postby ArT » Thu May 14, 2020 7:55 pm
This feature is already implemented in official update. Please update it to latest version. If you have still issue with blinking screen then there are a lot of interferences and you need to use different cable or make shield between wires (one wire can interfere with another wire - that's why stock tape is not round).
