SW_GND to GND ?
Pistou
Been thanked: 3 times
SW_GND to GND ?
Postby Pistou » Wed Dec 09, 2020 11:37 am
I can see on schematic that both signals are linked, is that already made internally in UTCOMP baord or Do I have to solder sw_gnd to gnd too ?
Re: SW_GND to GND ?
Postby ArT » Wed Dec 09, 2020 12:27 pm
SW_GND = switches ground on switches board. You have to connect SW_GND to UTCOMP ground.
Pistou
Re: SW_GND to GND ?
Postby Pistou » Wed Dec 09, 2020 2:11 pm
Ok I will; why is it not connected internally ? :ugeek:
Re: SW_GND to GND ?
Postby ArT » Wed Dec 09, 2020 2:46 pm
Because when you press switch it makes short circuit to GND, so ground line should be connected to switches board.
Just to make it clear - it's output ground for switch board. You do not have to connect it if you are not using switches.
