VSS hall sensor
Pistou
Been thanked: 3 times
VSS hall sensor
Postby Pistou » Thu Dec 17, 2020 12:52 pm
Is there any tutorial for VSS hall sensor?
If I'm already using 5 ADC, is it compatible with my setup?
Has thanked: 59 times
Re: VSS hall sensor
Postby ArT » Fri Dec 18, 2020 9:43 am
For VSS pulses you have dedicated input (pin A22). If you have VSS signal just connect it to this input. If you do not have VSS signal and you would like to assembly separate hall sensor, please check this manual https://www.reveltronics.com/downloads/ ... E4905L.pdf
Pistou
Re: VSS hall sensor
Postby Pistou » Fri Dec 18, 2020 10:12 am
Thank you Artur!
Well it's well explained but I'll not make this measurment, risk is too high in term of assembly.
Users browsing this forum: No registered users and 163 guests
