Cooler fan input A21
Scobo
Postby Scobo » Wed May 19, 2021 12:42 pm
Hi, is there possibility to have symbol / icon of fan when input is true and fan running?
Has thanked: 59 times
Re: Cooler fan input A21
Postby ArT » Wed May 19, 2021 2:19 pm
Engine temperature icon is changing from termometer to fan when cooler is enabled
Scobo
Postby Scobo » Wed May 19, 2021 3:24 pm
Aha, and if it will not, what should I do? When connected with usb-UTCOMP from Readings I can see A21 gets voltage and status changes.
Postby ArT » Thu May 20, 2021 1:37 pm
Please check if you have activated FAN in settings -> inputs/outputs -> pin a21 -> cooler
Now activate engine temperature on any screen and when you switch cooler input it will change icon from temperature to cooler
If it's not working please share me your utcomp settings file, I'll import it and check it.
Scobo
Postby Scobo » Thu May 20, 2021 3:05 pm
UTCOMP_v3-8_settings_2021-5-20_104539.zip
(3.77 KiB) Downloaded 767 times
I'm using 10. User (2) as default screen and that window oil symbol will not change, neither on DigOutUser control window.
Postby ArT » Fri May 21, 2021 12:43 pm
Ok located where is the issue. You have selected OIL TEMPERATURE, but fan is for engine - please activate ENGINE TEMPERATURE icon
Scobo
Postby Scobo » Fri May 21, 2021 12:54 pm
Aha, okay. Yes I'm measuring motor oil temp and control fan according that...so then clear. Thnx a lot for your great support!
Scobo
Postby Scobo » Tue May 25, 2021 3:36 pm
Still one question...
as I have air / oil cooled engine and measuring OIL TEMP - but as understood I should use ENGINE TEMP to get this fan running symbol...
I can swap ENGINE TEMP icon with OIL TEMP on "HARDWARE" -tab with "#FLASH" authorisation code, right?
So can you please confirm if this is correct > replace 32x16_temp_engine.bmp - 32x16_oil.bmp ?
So address: 0x6700 ( #define SPI_FLASH_ADDR_ICO_32x16_TEMP_ENGINE) to be replaced with 32x16_oil.bmp, right?
Thnx!
Postby ArT » Tue May 25, 2021 6:03 pm
Yes you can replace icon, but you can define your oil temperature as engine temperature, it will be different icon but it will work without any mods.
Users browsing this forum: No registered users and 203 guests
