4 pressure sensors, is it possible?
comboundTurbo
Postby comboundTurbo » Tue Jun 08, 2021 7:45 pm
hei
i have a compoundturbo mercedes, would it somehow be possible to get a clear input 2 pressure sensor for the turbo? high pressure and low pressure for turbo. and their 2 exhaust pressures?
i have a utcomp pro
Re: 4 pressure sensors, is it possible?
Postby ArT » Wed Jun 09, 2021 2:03 pm
Unfortunately you can set up maximum 3 pressures (boost, oil and fuel) so you will need to make a workaround, e.g. scale your pressure as other, not used value. For example if you are using PSI units you scale not used EGT as a pressure (range 0-1000), e.g. 1 EGT = 1 PSI, 100 EGT = 100PSI etc. Next you can change EGT icon to your own. If you are using BAR units you can use AFR (range 0.0 - 25.0).
