EGT sensor wires
Wolfgangh
EGT sensor wires
Postby Wolfgangh » Tue Aug 24, 2021 8:12 pm
Hello, I have just received my UTCOMP-PRO plus 4-ch. EGT-K and 2 EGT sensors. I am using this to setup carburators on a 4cylinder twostroke racebike (500cc). I want to know if I can shorten the sensor cables, or at least cut off the cable shoes? Would this change the output signal of the sensor? Also, can I buy the brass olives for the sensor mount alone?
Re: EGT sensor wires
Postby ArT » Wed Aug 25, 2021 6:17 pm
Yes you can shorten wires, it does not change readings at all. If you would like to extend thermocouple cables than it has to be special thermocouple type k cables.
Brass olivies are available in small set of compression lock:
https://www.reveltronics.com/en/shop/84 ... -84-detail
