Fuel consumption signal
gtbtdi
Re: Fuel consumption signal
Postby gtbtdi » Mon Sep 27, 2021 3:58 pm
I tried both PWM -/+ on pin 20 and 28.
After I changed to pin 28 (yellow wire) seems like there is no signal (zero on utcomp display).
Could it be that consumption calculation happens in the instrument cluster in this car?
I guess that Instrument cluster is connected via CAN-bus, So I might have to abandon hope of getting consumtion readings to the utcomp.
Has thanked: 59 times
Postby ArT » Mon Sep 27, 2021 4:12 pm
From my experience 1.9 TDI engines A** have fuel consumption signal on dedicated wire and engines B** sends data only via CAN BUS.
PWM+ for this type signal is correct one.
Does it count any impulses in diagnostic screen?
gtbtdi
Postby gtbtdi » Mon Sep 27, 2021 4:44 pm
Diagnostic screen shows no pulses from pin 28. And pin 20 shows pulses only when moving car.
Postby ArT » Mon Sep 27, 2021 4:51 pm
Pin 20 is definitely VSS.
Pin 28 seems like this output is not programmed, but it is fuel consumption signal in these ECUs.
You need to stay with PD signal, but scale it on longer distance (50-100km), you should achieve average accuracy about 5-10%.
gtbtdi
Postby gtbtdi » Mon Sep 27, 2021 5:21 pm
I have means to program ECU if enabling output is possible by just enabling it in some address.
Otherwise I will just use cars own (fading) MFA screen.
Thank you for your time and effort solving this problem.
Postby ArT » Tue Sep 28, 2021 8:56 am
It should be possible, but I do not have knowledge in this subject. It will require testing - replace with other ECU, check if fuel consumption signal is working and compare maps. But I'm still thinking why you have yellow wire at pin 28 in harness. Usually when fuel consumption signal is disabled (I had such situation in 1.9 TDI in Seat Altea) then wire is missing too. On the other hand, I had situation in Golf IV where wire was missing, but signal was there.
Users browsing this forum: Bing [Bot] and 169 guests
