Logging g-force
Gummisko
Logging g-force
Postby Gummisko » Wed Jul 13, 2022 12:53 am
Hi
I'm using a g-force sensor with a 0-5v output.
-3g = 1v
0g = 2.5v
+3g = 4v
So I did 2* a -5 to get it to show properly..
I have connected it to adc2 and displayed it as a boost pressure..
I did (x10) put in 20*a - 50 to get a more accurate reading, faking a extra decimal..
But how do I add decimals instead. I want 2 decimals..
As in the picture -9.6 bar is 0.96G
And is there a easy way to change text from "BAR" to "G-force"?
Re: Logging g-force
Postby ArT » Wed Jul 13, 2022 11:18 am
You can change "BAR" icon but you will change it for all readings, please check details here:
viewtopic.php?f=28&t=54
You can have 2 digits accuracy for boost when you connect Android device with UTCOMP android app (details viewtopic.php?f=21&t=322) - unfortunately there is not such option on display - only for Lambda readings there are 2 digits after comma implemented on display (because there is only 1 digit before comma for lambda - for boost can be 2 digits before comma - in both cases 3 digits in total)
Gummisko
Re: Logging g-force
Postby Gummisko » Tue Jul 19, 2022 12:02 pm
Thanks.
One more question
Is there a way to program the oil low pressure alert only when the RPM is above a choosed value?
Now I get low pressure alert every time I'm on idle
I want it to alert only on high rpm
Re: Logging g-force
Postby ArT » Tue Jul 19, 2022 12:40 pm
There is no option for RPM, but it can be related to battery voltage or boost pressure.
E.g. you can deactivate alert for boost pressure < 0.3 bar so it will not alert on idle.
