dual widebands on display
kens
Postby kens » Tue May 10, 2016 4:57 am
can two wide bands be displayed at the same time? I would like to monitor both banks on the display. Also just by rescaling I can display lambda instead of AFR correct?
Re: dual widebands on display
Postby ArT » Wed May 11, 2016 11:21 am
Generally it is single AFR to choose in app, but you can rescale any other linear value to get 2nd AFR (e.g. BAR/PSI from boost or oil pressure, EGT etc. if you not using it). Additionaly if you have UTCOMP-PRO than you can change icons, e.g. to AFR1 and AFR2:
http://www.reveltronics.com/forum/viewt ... ?f=28&t=54.
Yes you can rescale AFR to Lambda and change icons also.
edit 2016-10-16: in UTCOMP is already implemented dual AFR and dual lambda feature.
kens
Postby kens » Wed May 11, 2016 6:52 pm
THANKS
kens
Postby kens » Mon Jun 27, 2016 1:57 am
the EGT 4 setting will not convert to the Lambda setting. The EGT seems to be a fixed point number and i need a Floating. Please help.
I will be using the oil temp, 2 air temps and water temp along with the oil pressure and boost pressure once i am finished with my install. As for now the unit is not working as i hoped. I need a second calculation to feed the second Lambda output.
Thank you.
Postby ArT » Mon Jun 27, 2016 10:19 am
You are right and you should use x10 multiplier, e.g. for 13.5 -> 135, for 14.7 -> 147 etc. We will consider to add dedicated lambda readings in incoming update so it will be more friendly. Please send me a mail on PM so I can send you beta version for update when it will be ready.
Do you have any other issues? Oil temp + 2 air temps + water temp + oil pressure and boost pressure should work like a charm, so if you have any questions or need any help just let me know.
kens
Postby kens » Fri Jul 01, 2016 5:47 am
I am building my sensors this weekend -- I will let you know how it all works when i install the rest of the sensors.
kens
Postby kens » Sun Sep 04, 2016 5:06 pm
Everything worked out great --
any word on the update. I would like to have another afr input.
The pictures i haev are to large so i will have to fix that then post them
Postby ArT » Thu Sep 08, 2016 3:33 pm
We are working on it. We would like to add some other features too so it will be single update. Probably at the end of this month.
kens
Postby kens » Thu Sep 08, 2016 4:11 pm
That is great thank you !!!
Postby ArT » Mon Sep 19, 2016 3:36 pm
kens, could you explain me how important is to measure afr/lambda from 2 sensors (dual wideband) ?
I'm asking because we are during writing firmware for update. We have done already option to display lambda value (you can choose AFR or LAMBDA), but adding second bank for AFR/Lambda will consume a lot of time and quite much device's memory. With AFR/Lambda is associated alert system, data logger, sensor config etc. so for this "simple" mod there are a lot of changes in firmware to do and I need good explanation why it should be worth to do it, because anyone else has not asking for it.
Users browsing this forum: No registered users and 82 guests
