93 F350 IDI diesel lab rat
1mouse3
Postby 1mouse3 » Sat Apr 20, 2024 3:45 am
I 93 F350 that has a 7.3 idi diesel that I overhaled and made a custom twin turbo, so is easy to service on long runs. I rounded up a bunch of oem sensors, to serve as means to monitor vitals. I chose them, because I want to be able to stop at auto parts store to get replacement.
I am in the means of setting up a utcomp pro to serve as mean to monitor the vital of this engine, and the data logging fuction would aid in making adjustments to this engine. I have the cluster loosely mounted right now and need to come up with a better cover panel, the oem one cracked when I tried to drill new holes.
To get it to work, I trimed the speedometer a little so could be slid down some.
Then trimed the optional cover to fit in place, I will find some place else for the buttons.
Other engine and transmission options had a computer here, so put a plate in place and ran buckhead wiring through it
Here it is with some the planed wiring.
I had the wiring on the engine more tidey than this, but had to rummege around in to fix scramble wires when was checked on the truck.
I did dubble check it but that did not help much, with one color wire.
I stashed the box behind the cluster and will get velcro for it, to stick somewhere there.
Re: 93 F350 IDI diesel lab rat
Postby ArT » Mon Apr 22, 2024 11:07 am
Very nice, thank you for sharing it! :)
