Motorhours on display
Tom89
Postby Tom89 » Tue May 27, 2025 7:44 pm
1. Would it be possible to show the motorhours on one of the user defined screens (2,3,4)? I have a motor with a very short oil change interval -> 25 hours. So i need to check the motor hours pretty much every time to plan the maintenance. I didnt saw the option in the configuration software, but maybe its possible to add that function. That would be great.
2. The inspection/service alert is adjustable in the predefined steps 10, 20, 50 or does it also accept other values?
3. I guess the hour value is stored in a nonvolatile memory, so seperating the battery wont reset it. Right?
Otherwise UTCOMP has everything i would need
Thanks in advance
Re: Motorhours on display
Postby ArT » Wed May 28, 2025 9:44 am
Re1. motohours are not displayed in user screens, it's displayed during start up when time is running out. You can also display it manually by clicking button during startup or preview it in display setttings (long SW2). Motohours are configured in settings -> inspection -> motohours
Re2. You can manually enter next service in hours, e.g. for factory new UTCOMP you can set new service = 25h but after inspection reset from display it will be +10 or +20 or +50, but again - you can connect USB and manually set next service
Re3. exactly
