temp sensors
amirtiti
Has thanked: 5 times
temp sensors
Postby amirtiti » Mon Sep 05, 2016 2:31 pm
hi
i run into a small issue with the setting of my UTCOMP
i'm going to use 2 OE sensors (powered from ECU) so i will connect them to pins b2 & b3
now my problem is that i want to connect another NTC sensor and use it in pin a20 which will power it but i can't program it in the software
is there any solution for that?
thanks in advance
Re: temp sensors
Postby ArT » Thu Sep 08, 2016 3:31 pm
firmware supports 2x NTC and 4x DS sensors. We will check if possibile to add 3rd ntc sensor but could you use DS instead of NTC?
amirtiti
Re: temp sensors
Postby amirtiti » Thu Sep 08, 2016 11:22 pm
i already used all of them :roll:
please check if it possible to use the 3rd ntc sensor
it will be really helpful
plus, i forgot to mention in the first post
on the input\output chart B7 should be marked as B1 and B0 as B7
mistake or it is intentional?
Re: temp sensors
Postby ArT » Wed Sep 14, 2016 9:10 pm
B7 is DigOutUser
B1 is DigInUser
page 12 http://www.reveltronics.com/downloads/u ... manual.pdf
where did you find this misleading? I think it's mistake if it's different.
amirtiti
Re: temp sensors
Postby amirtiti » Thu Sep 15, 2016 8:29 am
you can see the mistake at the picture in the first post
Re: temp sensors
Postby ArT » Fri Sep 16, 2016 8:48 am
Thanks for pointing this. This mistake is in translation file and we will fix it. Thanks.
