Dear Revelprog Team,
my Revelprog-IS Software updated itself to V1.9.0 and I have Problems with the driver installation.
I tried under Help/install driver and install driver (zadig) but both fail (Driver installation cancelled by user)
The device is found in the Zadig Tool.
Thx for your help!
Wolfgang
Programmer is not connected (V1.9.0)
Re: Programmer is not connected (V1.9.0)
If you had v1.2.x or older - you need to uninstall manually driver from device manager (red led should blink) and then install it as described in manual.
If you had v1.3.x or newer - it should work with the same driver.
Does RED LED:
1. is off
2. is blinking
3. is on?
1 means that programmer has not power supply or is damaged
2 means that programmer is working but driver is not installed correctly
3 means that programmer is working and driver is installed correctly
Does RED LED:
1. is off
2. is blinking
3. is on?
The red LED is slowly blinking.
I try installing the driver, it looks exactly like seen in the Youtube Video.
But after I press "install Driver" it hangs (not responding). Yesterday, a Message box with "Driver installation cancelled by user" came up.
had the same problem again, I think its because the driver is not signed
it worked now, by disabling temporary the sign check. You should consider singing the driver in the future.
https://www.driversupport.com/knowledge ... ut%20issue
hi, I will nick this post.
having same issue
cannnot install drivers just says.
SMTicroelectronics STTub30 ready to use
REVELTRONICS Libusb0 libusb-win32 devices 06-28-2015 install failed
win 10 x64
yes i installing 64 version
did try manually - same thing.
having same issue
win 10 x64
