hi
i run into a small issue with the setting of my UTCOMP
i'm going to use 2 OE sensors (powered from ECU) so i will connect them to pins b2 & b3
now my problem is that i want to connect another NTC sensor and use it in pin a20 which will power it but i can't program it in the software
is there any solution for that?
thanks in advance
temp sensors
Re: temp sensors
i already used all of them
please check if it possible to use the 3rd ntc sensor
it will be really helpful
plus, i forgot to mention in the first post
on the input\output chart B7 should be marked as B1 and B0 as B7
mistake or it is intentional?
Re: temp sensors
B7 is DigOutUser
B1 is DigInUser
page 12 http://www.reveltronics.com/downloads/u ... manual.pdf
where did you find this misleading? I think it's mistake if it's different.
B1 is DigInUser
