Datalog
Donkerewolk
Datalog
Post by Donkerewolk »
Hey
I have some questions about the dataloging of the utcomp pro.
Would it be possible to datalog the parameters 2 or 4 times a second?
What happens if te memory is full? Does it overwrite the old data?
We want to use the utcomp as as simple race data loger/dysplay.
Thank you in advance.
Re: Datalog
In current version (v3.4) it is 1 sample per second. We are considering to make in update option for 5 samples per second for analog values, but I can not promise at this time because we have not tested it yet.
When memory is full it overwrites oldest data.
Donkerewolk
Re: Datalog
Thank you for your response, it would be great if you can realise that.
Grz
Re: Datalog
Just to let you know - 5 samples per second will be available for: speed, egt (all channels), afr (both channels), boost, oil pressure and fuel pressure. This function is already implemented and it is during tests so it should be available with v3.5 update.
