Tank Level Sensor
Tank Level Sensor
Hello, i have a little problem. My Tank Level Sensor is a Pull-down type ( measure resistance to Ground) and UTComp needs Pull-up to 5V. It isnt possible to use it as Pull-Up what can i do?
Re: Tank Level Sensor
In most cases voltage is in range of 0-5V. In older cars it may be 0-12V. I'm talking about stock sensors connected to AdcX input (if you want to connect additional sensor than it should be connected to AdcVccX and it should be minimum 1k ohm resistance range)
