I can see on schematic that both signals are linked, is that already made internally in UTCOMP baord or Do I have to solder sw_gnd to gnd too ?
SW_GND to GND ?
- Been thanked: 176 times
Re: SW_GND to GND ?
Because when you press switch it makes short circuit to GND, so ground line should be connected to switches board.
Just to make it clear - it's output ground for switch board. You do not have to connect it if you are not using switches.
