ArT wrote:This chip is supported with REVELPROG-IS (FLASH -> 25 series -> Winbond -> W25Q256JW). "E" package (page 94 in datasheet https://www.winbond.com/resource-files/ ... 082017.pdf) is WSON-8 8x6mm so you will need WSON-8 8x6 adapter for it (https://www.reveltronics.com/en/shop/56 ... -56-detail) to programm it in adapter. If you will have SOIC-8 or SOIC-16 package then you can use SOIC-8 or SOIC-16 clip (e.g. pomona 5250 or pomona 5252) and try to programm it in circuit without desoldering but success depends on motherboard and sometimes desoldering is required (please take a look Chapter 5 in REVELPROG-IS manual for details because there are many traps for young players and sometime it's safer & easier to desolder the chip: https://www.reveltronics.com/downloads/ ... manual.pdf). But you have WSON-8 package and there is any clip for it to programm it in circuit (WSON package has connection pins on the bottom). You can try to find FLASH SPI lines on motherboard and connect to them but I recommend to desolder the chip (e.g. with hot air gun) and programm it in dedicated adapter.
ArT wrote:Hi Markus, programming in external circuit always requires some knowledge and experience, even with REVELPROG-IS. We do not support CH341A, we are manufacturer of REVELPROG-IS. I highly recommend you to desolder the chip and programm it in adapter - it's safer. You can read more about possible traps in ICSP programming Chapter 5 of manual
Users browsing this forum: No registered users and 71 guests
